Re: Farmall Governor Springs
Posted by georgeky on August 27, 2007 at 17:48:50 from (205.188.116.73):
In Reply to: Farmall Governor Springs posted by Adam Brock on August 27, 2007 at 17:11:01:
You would need heavier governor weights. Don't think just springs will do it. You can speed it up a little by adjusting high idle. The adjustment screw is on top of governor housing. Place the throttle lever to wide open and turn screw to increase speed.
