GL1 is the "old" gear lube for which the Farmall transmission was designed. GL2 is the same stuff with some anti-corrosion/anti-moisture additives. GL3, 4 and 5 are the same stuff but with EP (extreme pressure) additives. These lubes are intended for worm and spiral bevel gear sets which operate under sliding and extremely high tooth loadings.
It's alleged certain EP additives can be corrosive to "yellow" (brass) transmission parts (bushings, cone synchronizers, etc). Also they may cause increased tooth wear in relatively lightly loaded straight spur and bevel gearsets such as are inside old Farmall transmissions.
However GL3 and higher oils will probably work fine in an old Farmall. (Fresh GL5 will certainly be better than the 50 - 60 year old oil and water mixture usually found in these things!) However given the choice I'd opt for the GL1 (or GL2) lube that these transmissions were originally designed for.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
