Re: 450 hyd pump seal
Posted by ejr-IA. on August 27, 2007 at 20:32:08 from (204.11.182.59):
In Reply to: 450 hyd pump seal posted by Ned in N.E. IN on August 27, 2007 at 18:55:25:
When you say oversized do you mean the large seal if so this is the No.363781R91 I found in the parts online at www.caseih.com
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
