Been There, Done That
Posted by A. Bohemian on August 28, 2007 at 08:42:22 from (207.170.88.145):
In Reply to: Re: super c smoke posted by leon on August 28, 2007 at 03:50:07:
We operated our Super C for many, many years with it blowing oil smoke past the rings.
We used all the typical tricks to keep it running, and kept a sharp eye on the oil pressure guage. As long is it didn't drop to almost zero, and bounced back up as soon as you advanced the throttle (and it always did), we didn't worry about it.
Finally came the day when nothing I could do would make the tractor pull a load. It started on the first pull of the crank, idled great, responded well to the engine speed control, did not not miss when not under load, still had reasonable if poor oil pressure, never overheated, etc.
But it wouldn't do any but the lightest work.
So I did a compression check. I didn't like the readings and I had sleeves and pistons put in and a valve job done.
The tractor runs great now. But here's the moral: on the cylinder which finially gave out, combustion products rushing through the gap in the cracked ring burned THROUGH the sleeve. I mean right through it.
Had I continued to run the tractor much longer without new pistons and sleeves, I might well have damaged the block.
So, even though you can make the tractor run and run well WITHOUT fixing the rings, don't wait TOO long...
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
