farmall's.
Posted by kirk in ks, on August 28, 2007 at 13:42:32 from (24.225.28.37):
If I pull with the W-6?
is it hard on the rear end, and will it tear it up any doing it,
I saw a 4586 on you tube, and it was really cool as that V8 diesel really sounded good,
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
