Re: am trying to get a 42 model H to run
Posted by jonnny2006 on August 28, 2007 at 23:14:29 from (67.142.130.18):
In Reply to: am trying to get a 42 model H to run posted by James Kleinheider on August 28, 2007 at 21:45:06:
Has to be a fuel......if it was spark it would die even when you spray starting fluid. do a flo test and check the carb screen and the sediment bowl screen. or it might be in the carb itself like the float. Does it run if you choke it?
