Re: am trying to get a 42 model H to run
Posted by El Toro on August 29, 2007 at 03:58:31 from (205.188.116.73):
In Reply to: am trying to get a 42 model H to run posted by James Kleinheider on August 28, 2007 at 21:45:06:
Hold your hand over the throat of the carburetor and see if there's good suction and your hand should get wet with gas. The inlet screen where
where your gas line is connected could be be plugged with rust or dirt or both. Shine a good flashlight down in the gas tank and see if there's any crud floating around. If there's an inline filter it could be the problem if its not for a gravity flow system. Most are for when using a fuel pump. Hal
