Re: Broken Magneto Flange
Posted by El Toro on August 29, 2007 at 04:19:44 from (205.188.116.73):
In Reply to: Broken Magneto Flange posted by aw738 on August 28, 2007 at 17:59:45:
Check with your local Case/IH dealer to see if they have the mounting flange. Some dealers have used parts. If you pull that mag off the engine
make sure you make a note of where the rotor is pointing. Make a sketch and then don't turn the engine while the mag is off. When reinstalling the mag just turn the rotor to the position on your sketch and your mag should be in time. This applies to a distributor too. Call 1-800-732-0017 to see if they have a mounting flange. You will need to ask for farm tractor parts. Hal
