Re: am trying to get a 42 model H to run
Posted by Michael Soldan on August 29, 2007 at 05:05:14 from (24.235.42.138):
In Reply to: am trying to get a 42 model H to run posted by James Kleinheider on August 28, 2007 at 21:45:06:
Your description indicates fuel shortage. As suggested remove line at carb or the plug on the carb. Here is where most people get decieved..they see gasoline and say, yep we got fuel!...well you need a flow that is steady and continuous and as was suggested let it flow for several minutes catching it in a container..the flow should be like you could pee when you were 16!...if you don't have a contiuous flow the problem is between the tank and the carb. The screens in the sediment bowl often plug up and that is a good starting point in cleaning the fuel system
