Re: cutout vs. relay
Posted by John T on August 29, 2007 at 06:23:03 from (66.244.83.147):
In Reply to: cutout vs. relay posted by bnowen on August 28, 2007 at 21:02:28:
You first gotta understand the difference in a 2 wire Cutout Relay (most used the older 3 brush adjustable genny) versus a 3 or 4 terminal full fledged Voltage Regulator and go one way or the other. If you use a 2 wire Cutout Relay (BAT and GEN/ARM terminals) the gennys Field post wires up to a correct LHBD light switch where it gets either a dead ground for High Charge or a resistive ground (on back of switch) for Low Charge.
The Cutout relay wires: BAT terminal to Load (NOT battery/Starter) side of ammeter. GEN/ARM terminal to ARM post on genny. Gennys Field post wires up to a correct LHBD light switch.
A 4 terminal (LOAD BAT FLD ARM) VR wires:
BAT to load side of ammeter
FLD to gennys Fld post
ARM to gennys ARM post
LOAD feeds hot battery voltage up to loads
like lights or ignition (if a coil ignition)
often via a connection to their switches BAT
input terminal
A 3 terminal (BAT ARM FLD) VR wires:
and loads get their voltage off the load
side of the ammeter (same post that wires to
BAT down on the VR)
Make sure the belt is good n tight and POLARIZE the Genny BEFORE you fire her up n see what happens?????????????????
Which (VR or Cutout Relay) do you have now??? What light switch do you have now???
EITHER a Cutout Relay (provided the right LHBD switch) or a VR will work and if you have a true magneto (NOT one modified as a coil ignition) it has nuttin to do with the charging system and the Mag dont get wired to none of the charging stuff, perhaps a ground out kill switch somewhere.
Nowwwwwwww once you get it wired up correctly with a Cutout Relay orrrrr a Voltage Regulator and its polarized but still dont charge, if you still need my Complete Troubleshooting Procedure for non charging and how to tell if its a genny or a VR/Relay problem, post back n let me know
John T
