Posted by SuperA-Tx on August 29, 2007 at 06:59:51 from (4.90.52.54):
The inner ends on my tie rods had been welded, looks like some kind of field repair.
OEM has the inner end and tube that they say is correct for a SA. Their tube is 17 inches long but I measured the old tube on mine and it is 13 inches. Since mines been welded it hard to tell what it might have been to start with.
I then measured the ones on out 140's and the tube is 16 inches long.
The outer ends on mine are differant from the inner ends so I will re-use them. The outer ends are like on a cub if that makes any differance.
Can someone tell me the total length of the tube on their SA tie rod or what is the correct length. I am thinking I may have to cut the new ones down to make them work right.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
