I also have a 42 H, but had similar problem with my 48 MV. My problem was a LOT of rust, dust, crud in the gas tank. If this is your problem, then you may want to do what I did: Drain tank; Remove tank; dry it; flush with water hose; shine flashlight in and poke with a wooden stick to scrape off all loose crud; put some nuts and bolts in it and tumble it around to loosen crud; keep flushing till it comes out clean; get etching acid and follow directions; get a product called Red-Kote and coat the inside of the tank to prevent the problem from happening again. Add a new sediment bowl with good filter. I did all this and now it runs and stays running!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
