Re: Farmall B - gas line again
Posted by Dave H (MI) on August 29, 2007 at 14:12:20 from (64.12.116.73):
In Reply to: Re: Farmall B - gas line again posted by Yugrotcart on August 29, 2007 at 13:59:31:
Thanks Paul, but I have been to no less than nine auto parts stores, two plumbing supply houses, and the "old-timey" hardware that sells everything and have been told by each and every one of these that nobody will have a male fitting of that size. I did not believe it, but was true.
Anyhow, got the fittings at the bone yard along with a used gas line with the same coppery finish as the original EXCEPT this one turned out really was copper so I had to scrap it for the fittings.
Just really don't have it in me to go buy brake line on spec because I don't see how it would work any differently than the original 5/16 steel line I am trying to install now. Won't the brake line pull out the end of the fitting too? If not I sure would like to know how that works. Sorry to sound so frustrated but I have about ten days of waiting and a lot of money into something that seems like it should be so simple.
