Re: Farmall B - gas line again
Posted by Janicholson on August 29, 2007 at 16:07:09 from (66.173.50.170):
In Reply to: Farmall B - gas line again posted by Dave H (MI) on August 29, 2007 at 13:53:08:
Dear Dave, There may be one or two issues now. One may be that the threads in the sediment bowl are bad, limiting the seating of the fitting.
The second is the use of a new brass compression ferule (the little brass ring that is put on the line after the threaded part is slid down a ways. This compression ferule is available at hard ware stores. If it has been compressed, and abused to remove it, it will need to be replaced. This may be frustrating, but (though "educational") it will be correct. JimN Still believing
