Re: Cub, low oil pressure
Posted by Gene on August 29, 2007 at 17:25:54 from (64.85.216.53):
In Reply to: Cub, low oil pressure posted by Haas on August 28, 2007 at 18:31:50:
There is another main oil gallery plug (allen headed screw) under the valve cover. Almost dead center. Once in a great while this one gets left out. Check this one out first. It's an easy replacement if missing.
I think there is another on the rear of the engine plugging the main oil gallery. However, if this one is missing you would have large quantities of oil draining out the bellhousing. The others drain oil back into the oil pan.
