Re: Hugh MacKay help
Posted by georgeky on August 29, 2007 at 18:31:51 from (205.188.116.73):
In Reply to: Re: Hugh MacKay help posted by Rob Baird on August 29, 2007 at 18:20:28:
Rob, if money is no big problem I would put the pressure plate and new throwout bearing in it too. I would inspect the one you take out first though as it may not be worn out at all. It is not to big a job to do this. Your manual will explain the splitting procedures. To remove the old ring gear just heat with a torch and it will come right off. Then heat the new one and it will go right on and seat as it cools off. You may have to knock the old one off with a ham,mer after heating.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
