Re: A Boiling Noise
Posted by ScottyHOMEy on August 29, 2007 at 18:42:09 from (71.241.221.231):
In Reply to: A Boiling Noise posted by NYVINES on August 29, 2007 at 17:36:45:
I'm kind with Bob on this one.
Has the tractor been working/moving around or just running in the garage getting it ready to work?
Some bubbling noise is not unusual but your description of a percing coffee pot sounds like a bit much. Try running the front of the tractor up an incline, if it hasn't aleady been on one. If there is a bubble at the back of the head or anywhere else, that ought to help clear it.
Also wondering what you have in there. Straight water will tend to make more bubbles than a water/anti-freeze mix, as it gets closer to its boiling point than does the solution of the two.
