OT Hydrualics... Maybe someone can help
Posted by Red Lane on August 29, 2007 at 19:18:44 from (170.215.20.75):
third party image
Im taking apart a hydrualic cylinder off of a koyker loader, not sure if thats the brand of cylinder, its off of the grapple. I need to replace some seals but I got so far, now stuck. Came apart real easy but what I need to know if this barrel is pressed on, screwed on, or just stuck and needs a little (or big) tap. If its screwed on, what should be used to get it loose, with out marring (the nut on the end is loose and tightens to the barrel). Any ideas. Thank you
