Re: Farmall B - gas line again
Posted by banjo on August 29, 2007 at 20:35:37 from (65.67.203.55):
In Reply to: Farmall B - gas line again posted by Dave H (MI) on August 29, 2007 at 13:53:08:
I used the 5/16 brake line, new sediment bowl assembly and it works like new. You can buy the fittings from TM tractor supply.if your sediment bowl is in good shape the compression fitting will work.
But it is always best to shut the fuel off if it is going to set for a while.
