Re: reversing a 460
Posted by Owen Aaland on August 30, 2007 at 06:23:32 from (65.161.86.86):
In Reply to: Re: reversing a 460 posted by Hugh MacKay on August 30, 2007 at 02:28:28:
Once the carrier is reversed you will find that the shirt forks no longer fit. You will also need shift forks for the reversed drive and move the shift lever to the other deck hole. The forks can be made by cutting the forks off the sliding bars, turning them 180 degrees, and rewelding them.
