Re: reversing a 460
Posted by NDS on August 30, 2007 at 06:29:09 from (205.188.116.73):
In Reply to: Re: reversing a 460 posted by Hugh MacKay on August 30, 2007 at 02:28:28:
Hugh: Have never reversed a 460 but have M and 400 and there is a little more involved than flipping ring gear. When ring gear is flipped it is directly under shifter and will not clear so shifter has to be moved to other side. The 460 has 2 shifter position deck cover and bosses for needed bolts but holes are not drilled and tapped (at least not on 400) and shifter forks will not work on opposite side so you have to find reverse operation shifting forks or reconfigure the foward operation forks. Like I said before this applies to 400 but I would think 460 would be the same. When our 400 was coverted for cotton picker operation they used reversed operation attchment kit and did not use original deck cover.
