Re: dying shows/ revisited
Posted by onefarmer on August 30, 2007 at 06:48:03 from (209.153.128.248):
In Reply to: Re: dying shows/ revisited posted by russ hamm on August 29, 2007 at 18:27:45:
I agree. Some could be planted in the spring so a cultivation exibition could be done, along side a how it was planted exibition
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
