Re: Farmall C VS 140
Posted by Ron-Mo on August 30, 2007 at 09:54:12 from (208.210.74.251):
In Reply to: Farmall C VS 140 posted by Bigfutty on August 30, 2007 at 07:22:27:
One time I had a pilot bearing going bad in a pickup. I took the transmission out and only replaced the bearing. Bad mistake. Within a year I had a throwout bearing failing as well. I learned from my mistake and replace everything in the clutch, including the pilot bearing I had just replaced. You don't want to pull a transmission, or split a tractor for a $25 part when you were just in there. Now, I always replace everything whether I think it needs it or not. P.S. the truck is still going about 8 - 10 years later.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
