Posted by John in Ct on August 30, 2007 at 13:54:54 from (69.24.45.45):
I tried to adjust the carb on my Farmall H and am not having too much luck. I set the throttle to high idle, screwed in the main adjusting screw until the engine started to run rough, then backed it out 1/2 turn. I set the low sped air screw 1 1/2 turn out. I tried the tractor with the low speed screw in some, out some and the tractor still sputters when I pull the throttle. I have had this carb apart many times trying to get the needle valve to stop leaking and think I may have solved that problem. I clean and blow out all passages so I think the carb is clean inside. Any ideas? Thanks!!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
