Re: A Boiling Noise
Posted by Gene on August 30, 2007 at 18:17:06 from (64.85.216.180):
In Reply to: A Boiling Noise posted by NYVINES on August 29, 2007 at 17:36:45:
Thermosyphon systems have a tendency for crud to settle in the lower portions of the cooling system. And particularly around the #4 cylinder. If you have not flushed the block - suggest you do so. Build up of crud will cause the cylinders to overheat and score.
