Re: Gear oil revisted, Bob M others
Posted by Paul Shuler on August 30, 2007 at 19:14:06 from (170.29.248.3):
In Reply to: Re: Gear oil revisted, Bob M others posted by John in Ct on August 30, 2007 at 19:02:02:
John I have that in a Super C I went through about 8 years ago and it has done fine. I couldn't tell you what the GL rating was. My super C does not see a lot of work but the rear end is very quite on it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
