Re: 560 vs 660 differential housings
Posted by Wardner on August 30, 2007 at 20:20:36 from (4.154.241.42):
In Reply to: Re: 560 vs 660 differential housings posted by KIP in MX on August 30, 2007 at 19:04:56:
Not only will they bolt up to a 560, they will bolt up to a M and later same sized tractors.
Lets assume that you have a M-SM and you want to go slow, real slow. You could put in the M-SM low-low first gear kit, one of the 560-660 differential sets (I forget which one and I not going to look it up unless requested), and the planetary axle. The 660 also had an optional tire size that may give a further reduction.
You could also modify a SMTA w/TA and later tractors (low-low kit is not available) for a substantial reduction. In that case you would use the F560 first gear.
I am not up to pouring thru the parts books and doing the math at this moment. I will say that I built a SMTA with F560 differential gears, F560 first gear, good TA, and 15.5x38 tires. It's a creeper in first gear low range. Top governed speed in direct is 11 mph.
