Re: Farmall M won't shut off
Posted by Janicholson on August 31, 2007 at 09:04:56 from (199.17.6.122):
In Reply to: Farmall M won't shut off posted by BOBM25 on August 31, 2007 at 08:46:59:
There is no relationship between timing (unless it is so far out that the tractor is badly overheated) and run on. The ignition is shut off when the button is in, thus no effect.
I agree with Old on most (except carb cleaner should not be sprayed into a running engine, the combustion makes the fumes highly toxic, a friend near died)
Setting the Idle as slow as it will run reliably and not stall, and just as lean as can be set with good running will also assist shutdown. If it has above 150psi compression, premium fuel, or a 50/50 blend of reg and 92 will also cure part of it. JimN
