826 PTO got me stumped.
Posted by Bradford on August 31, 2007 at 19:11:58 from (76.30.247.168):
The PTO (dual speed) will turn when the engine is off. So it isn't froze. And it turns with the engine running. But the valve to stop it doesn't work.
I pulled the drawbar support and dropped the valve from the bottom. The little pin is in place so the stem and control valve are together.
but it just flops up and down.
Here are the problems, there isn't an adjustment nut and the top stem has the head broke off. A little below where it broke off there is a 1/16 hole that has a cotter key which is hooked to a bunge cord to activate it!! There also isn't a bumper spring under the big nut on top.
when I pull up on the stem even hard enough to squeeze the two springs under the control valve nothing the pto keeps turning with what seems like full power.
I am thinking the previous owner just ran it with the pto going all the time which isn't very safe i believe.
does this look like a rebuild? I am gonna get the missing parts and hook up a gauge next like the IT manual says.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
