I agree. And typically a engine that continues to run is running hot on the spark causing the plug to continue glowing (dieseling like glow plug) which forces it to continue running. Choking it wont fix the real problem. If it is running the plugs to hot, it can cause serious damage to the engine like hole in piston, metal in cylinder wall (like melted plug tip) etc etc.
A hot plug can be from over advanced timing. It can also be from wrong temp plug that is too high temp spark rating. Also make SURE to set the spark plug gap to spec, and use manufacturers recomended plug to ensure correct temp. Set the timing for sure. I would check the points too while your at it. A super lean engine I think could cause it. But everytime Ive seen this its been related to spark one way or another.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
