Re: X3, X17, and no suffix difference?
Posted by RustyFarmall on September 01, 2007 at 05:02:15 from (66.43.253.55):
In Reply to: Re: X3, X17, and no suffix difference? posted by Mike CA on August 31, 2007 at 19:30:12:
I think the only difference in the carbs may have been the main metering stem and those are fully interchangeable. The other difference is that the distillate and kerosene carbs had a petcock drain in the fuel bowl and the gasoline carbs usually had a simple 1/8" pipe plug in the drain hole. I say usually, there is some evidence that a few of the gasoline carbs DID have the drain petcock.
