Re: X3, X17, and no suffix difference?
Posted by Harold H on September 01, 2007 at 08:44:09 from (71.29.0.105):
In Reply to: X3, X17, and no suffix difference? posted by Mike CA on August 31, 2007 at 19:30:12:
The compression ratio was also different for each; kerosene, distilate, and gasoline plus for altitude options.
Harold H
Mike CA said: (quoted from post at 19:30:12 08/31/07)
RustyFarmall said: (quoted from post at 18:48:58 08/31/07) At the time your tractor was built, distillate fuel was the standard, kerosene was an option, as was gasoline. Because your tractor was a "standard issue" there did not need to be a suffix to identify the fuel type. Kerosene and distillate are not the same kind of fuel.
That explains X3 and X1, but then why X17?
Do you know the difference between set up? Was the carb different or something?
