How do you tell when your hydraulic reservoir is full enough
Posted by Butch WI on September 01, 2007 at 11:24:28 from (69.19.14.38):
I was cutting hay today with the 460u and had slow remote hyd response. I added 2.5 gals and then it responded quicker. Now I know it has some very small (mostly weeping) leaks, but I couldn't have lost much fluid to make it pump slow again. How do I tell when there is enough fluid in the system when performing a top off? It's easy to do when you do a filter & fluid change, but what is your rule of thumb adding.
I have only 1 remote and the fast hitch operates slow too!
Can it be filled too full?
Cutting hay was great! I used a neighbors old trailer type sickle mower. As many of you know, you NEED hydraulics to operate it.
I'll get some pix posted soon!
TIA
Butch
