Re: Farmall 140 Starter Switch Problem.....?
Posted by Janicholson on September 01, 2007 at 14:59:43 from (66.173.50.106):
In Reply to: Farmall 140 Starter Switch Problem.....? posted by keith stromberg on September 01, 2007 at 13:50:22:
I agree with Old
It also seems that you have the system negative ground, which works with an alternator, or a gen polarized to be Neg ground. Starter draw with a cheap meter that is held against the bat cable should be less than 300 amps for that tractor if more, rebuild the starter. JimN
