Re: Eureka with H...almost.....helppppp!
Posted by glennster on September 01, 2007 at 17:36:01 from (68.60.242.156):
In Reply to: Eureka with H...almost.....helppppp! posted by hbauer on September 01, 2007 at 17:09:06:
first check if the bendix in the starter is jammed up to the flywheel, with the tractor in 5th, key off, gently rock the back wheel to turn the motor a little bit, you only need a 1/4 inch or so, then try and start it again. you can also loosen the starter mount bolts a few turns out ad wiggle the starter. next, check all your battery cables for corrosion and clean them up. you should be running big cables if its 6v. if that still doesnt correct it, you may need to have the starter rebuilt. the bushings wear and the armature gets pulled kinda sideways, eating up a lot of power, or you may have an internal short in the starter.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
