Re: Eureka with H...almost.....helppppp!
Posted by mulcher on September 01, 2007 at 18:47:24 from (64.187.75.15):
In Reply to: Eureka with H...almost.....helppppp! posted by hbauer on September 01, 2007 at 17:09:06:
I was mowing with a H today. Had to jump it to get it started because the starter switch won't make contact anymore. Tonight I took it apart and years of being outside made the contacts corroded. Tried to clean them up and put it back together but the little tabs that hold it together broke off so off to the auto parts store tomorrow for a new one. This one looked like it had been hot at one time to. H's had different kinds of starter switches. This one is fairly large and has large cables to it and sets by the steering wheel. If you have a starter solenoid then thats probably been added. My W9 has had starter solenoid added to it and I have had it stick several times. Always have to tap it to make sure it shuts off or the starter stays engaged and things get hot.The H I was using today is the neighbors. Wish it was mine, neat little tractor.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
