Re: Rapping noise after backfire
Posted by Ken L. on September 02, 2007 at 06:57:24 from (72.1.20.114):
In Reply to: Rapping noise after backfire posted by Alan Chalou on September 02, 2007 at 03:13:32:
Had this happen to a freind of mine years back. He called and said that his M backfired and there was an upper end knock after that. Checked above the head and everything seemed good. I pulled the head and found a screw head embedded in the #2 piston head which, would hit the cyl. head each time the piston was up. Pulled the carb and found the head of a screw from the choke butterfly missing and the other screw stretched and bent. If you've checked what the other guys said to check and have found nothing, pull the carb and check the four butterfly screws.
