Re: Farmall 140 Starter Switch Problem.....?
Posted by SuperA-Tx on September 02, 2007 at 10:17:24 from (4.90.2.22):
In Reply to: Re: Farmall 140 Starter Switch Problem.....? posted by keith stromberg on September 01, 2007 at 19:50:16:
The starter button should be mounted on the instrument panel and not on the starter like on a SA. Basicly the same tho just mounted in a differant spot.
Take the starter off and take it to an Alternator place and have them check the starter out.
While its out clean up all the connections. Might even get a new battery cable if the old one is wore out.
