Re: Need some opinions on block drain
Posted by Tired 300 in Mn on September 02, 2007 at 12:38:31 from (216.251.181.156):
In Reply to: Need some opinions on block drain posted by Mike CA on September 02, 2007 at 12:12:49:
Looks like an old vacuum petcock from a dairy barn. Thread was likely correct. Thread damage may have occurred when it was removed from vacuum header. Wouldn't have much value here in Mn. as they were found on every farm 30 years ago. I would use a tap to clean threads before installing new plug. Sonny
