Randy Hall
Posted by Larry806 on September 02, 2007 at 13:09:57 from (74.218.14.82):
third party image
Hey Randy get yours running yet?
Mine was " lightly stuck " Phil could move it a little each way but it
wouldn't turn .
I found the clutch housing full of mice nests . When I got that cleaned out
it turned over . It will have to be split and ring gear cleaned & new clutch
. That is much better than having to get in the motor .The shaft was broke
in the Hy pump . Lucky I have a SMD for parts . The radiator was still full
of antifreeze when I took it off .
We took the valve cover off and everything in there looks new . I pulled the
oil pan and it looks like a low hour rebuild !
I don't even have a Hy pump or dist. on it . But this morning Phil came over
and wanted to pull start it . He pulled me about 10 yards and the fuel
system bleed out . He didn't pull it 100 yards and it was running on diesel
! I only let it run a minute or so because of the radiator being off .
I'm happy today !!!
