Re: Electrical system decisions
Posted by Janicholson on September 03, 2007 at 14:40:44 from (66.173.50.166):
In Reply to: Electrical system decisions posted by Mike CA on September 03, 2007 at 11:11:17:
In my opinion, the starting point would be to get it running the way it is. the prior owner did fair wiring, and at least bundled it. When money and time permit, hunt for and get a wire loom for the tractor (commercial pre-made unit) and hunt for a 12 volt generator and correct regulator. for 12v negative ground. (if you want to be correct police perfect, it needs to be 6v pos ground) The wires look serviceable and are OK and probably located where they belong. The battery shelf is wrong, it needs a battery box with sliding bolts on the bottom and a lid that slides under the fuel tank in that location. The best bet is to get it running. JimN
