Posted by Wayne in MN on September 03, 2007 at 19:17:20 from (24.181.155.162):
In Reply to: Farmall B - Carb posted by Dave H (MI) on September 03, 2007 at 16:17:28:
The idle air screw should be turned in or out until the engine idles smoothly. Any setting in a book is just a starting point for further adjustments. If the idle air screw is not able to do it's job, then you need further cleaning of the idle circuit in the carb. I have cleaned and adjusted more carbs than I can count in the past 50+ years. They can be "interesting" sometimes. Send an e-mail if you need further info.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
