Posted by karl f on September 04, 2007 at 14:02:19 from (172.131.159.145):
In Reply to: 656 or 856 posted by Hayfarmer on September 03, 2007 at 20:56:39:
656 is more maneuverable in the yard or small spaces. what type of use do you intend? on our operation, the 656 is much better in our small fields under 40 acres (some as small as 6-8) even though the bigger tractors do amazing work in the larger fields where you aren't turning as often. also consider your soil conditions. the 656 is the biggest tractor we want in the wet areas or the cow yard in spring time. have had the bigger one stuck with only an empty balefork attatched in the cow yard. bigger tractor also compacts the hay meadows worse. considering a tractor can be complicated! karl f
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
