Re: Farmall B - oil filters
Posted by georgeky on September 04, 2007 at 14:33:05 from (64.12.116.73):
In Reply to: Farmall B - oil filters posted by Dave H (MI) on September 04, 2007 at 13:19:13:
Dave, call Brad at 1-888-824-0544. He will send you any part you need for that thing. He also knows the part numbers for most Farmall parts. Any part or gasket is available for that thing. Unlike some other makes, Farmall parts are easily found at IH dealers who are willing to look for them. Even new gears and things are still available. Like the others have said you have moisture in your oil whether it be from a leak or condensation you have water in there. Might be a head gasket or somthing cracked. May even just be a loose head. Could also be a bad sealing ring on a sleeve seaping a little. Try to retorque the head and see if it stops any leak there.
