Has any one used the GRABIT????
Posted by jonnny2006 on September 04, 2007 at 19:31:25 from (67.142.130.39):
I was watching tv and seen a commerical for GRABIT. They claim that it will remove any stripped bolt or screw in seconds. Has anyone used it? It looks like it would save alot of time tring to get out stripped and damaged bolts. I have a broken idle mixing jet on my 44 H and would like to put in a new one but there is nothing to grab as it is busted flush.
