Re: Solenoid on starter?
Posted by Hayfarmer on September 05, 2007 at 07:00:12 from (66.243.235.184):
In Reply to: Solenoid on starter? posted by Carden on September 05, 2007 at 05:48:48:
I converted my SMTA to a button soon after I got it. A guy who repairs starters and such, removed the contact from the original setup and soldered a starter bolt in it's place. I use a Ford type solenoid mounted near the starter. I like the setup, seemed like I had trouble with the original switch going bad or the contact getting corroded or misshapen. Anyway it worked for me. Prior to converting my tractor to electronic ignition, I used the 6 volt coil with a resister. With the Ford solenoid you can bypass the resister for starting.
