I am ALSO happy to observe you are apparenlty paying attention to your dashboard ammeter. So many people, when they first encounter what they think is an electrical problem, start unscrewing and replacing caps, rotors, coils, condensors, etc., etc., without really having a clear idea of what the problem might be; the dashboard ammeter can often help us narrow down the potential sources of the problem.
Before you decide to replace or rebuild the generator, you might want to try the following tests:
(1) Look for obvious physical problems: burned wires, wires dangling loose, slipping belt, etc.
(2) Get one of those test wires with alligator clips (or crocodile clips, depending on how you hold them) on both ends. Clip one end to the regulator base and the other to a good ground connection. If the ammeter suddenly shows a charge, check and clean the grounding surfaces.
(3) Run your test leads between the ARM or GEN terminals and the BAT terminal. If you show a charge, you can take the regulator apart and try to clean and adjust everything, or you can try a new regulator.
(4) If none of the above has made a difference in the charging rate, run your test lead between the FIELD terminal and ground. If the charging rate increase, ditto the above about cleaning or replacing the regulator.
Thus easily, using a simple wire and the invaluable dashboard ammeter, can one diagnose many common voltage regulator failures.
I don"t know what to tell you about whether to replace the regulator or clean it. On the one hand, there is a good chance the regulator you already have is more rugged than any replacement you"re going to find.
On the other hand, not all regulator overhauls are successful, and then one has wasted time...
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
