Re: Up Date Running with the choke out
Posted by Jrry on September 05, 2007 at 10:21:35 from (205.144.229.8):
In Reply to: Up Date Running with the choke out posted by Larry in GA. on September 04, 2007 at 10:39:58:
I had a similar problem on my 950. It turned out the gas lid was on too tight. I loosened it and have not had any futher problem. I hope your problem thurns out as simple as mine.
