Re: W-6 stuff?
Posted by chadd on September 05, 2007 at 11:50:32 from (155.92.30.112):
In Reply to: W-6 stuff? posted by kirk in ks, on September 05, 2007 at 09:27:34:
Nope, Nat 2 has the right idea. The timing marks are exactly the same as an M. The timing pointer is on the crankcase front cover on the carburetor side of the engine. If the tractor is very greasy, you may need to clean the grease off to find it. It is about 3/4 of an inch long and about 1/2 inch in diameter. There are 3 notches in the water pump pulley flange. The notch out by itself is not used on a W6 and indicates that the grease fitting for the pilot bearing is lined up with the peep hole in the casting of the bellhousing on a Farmall M. (I say it isn't used, because the W6 has the hole located about 30 or 40 degrees off from the bottom of the casting; the W6 still has a grease fitting for the pilot bearing, just that you need to use trial and error to find it) The other two marks are very close to each other. The one you want is the first mark that comes up when turning the engine over in its operational (running) direction (clockwise when standing at the front of the tractor. If you are looking at the timing pointer, it should be at TDC when it is in register with the lower of the two notches on the pulley. Also, while you are in the area, please note the grease fitting on the crankshaft support bracket, it should be greased every once in a while.(A Farmall M or a Super W6 with a channel frame will not have the grease fitting on the crank)
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
