The posts below are probably hitting the target. I come from an area of indiana with glacial deposits of fine yellow clay. In some spots, in some years there was no possible plowing done. While building I-94 interstate in 67, the earthmovers were twin engine Euclids and were pushed by 2 D9 dozers each. When cutting 3 inches of clay, the clay would come off the blade and shelf up over and out of the hopper like a curl of wood from an old fashoned block plane. To check the sharpness of point and share, set the plow down on concrete, and look at the tip of the share and point where they encounter the solid surface. If the tip of the point is more than about a quarter inch above the surface, it needs a new point. If the share looks rounded on the leading edge, and is more than 1/4 to a half inch radius, it might be good to compare it to a new one. JimN
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
